random question,,, can a TRZ Poly dogbone Rear Mount be installed without jacking/lifting your car from the ground?.?. there might be barely enough space under there.... right??? haha.... because I want to install the item myself, but I don't have a jack.
I went on a mod shopping spree last night, TRZ rear mount, Forge BPV (sonic FTW!), and rally armor mudflaps. I am going to avoid my credit card bill for as long as possible, lol.
thx
If you can fit under the car I don't see a problem. But if you can fit under the car when its not on a jack then you have an eating disorder and i'll buy you a hamburger and force it down your throat.
The rear motor mount is not load bearing so the motor doesn't have to be supported to take off the mount.
If you need a jack, then I know you close to Boston but you could make the trek out here and I could install it for you. Rear wheels need to come off to install the rally armor flaps anyway so you will need to have a jack one way or the other.
