4
43975
Damn Justin I thought My s*** spit black smoke your's wins there
You have a solution in the works? Do you have a DP?
what did the speed6 put down?
I would also like to apologize to anyone that had to smell my car.
Anna thanks a ton for setting this up!! I had a great time and it seems everyo e else did as well.
2wd dyno couldn't run ms6's.
All of the DISI's inherently knock. I have a theory that most of it is false knock from the noisy drivetrain, but regardless... the sensor thinks it's hearing knock... so it's retarding timing. Combine that with running pig rich and here we are.
I've got a used downpipe I'm gettin' in the next few weeks- leaning it out will do a lot, alone. There's a possibility that it's dumping so much fuel it's burning the spark plugs out and missing, even.
Regardless, it needs tune, meth, and a few more air-moving parts and it'll clear up.
I've been slacking on the vids. I'll throw yours up soon Doc. Anyone else who wants theirs lemme know because of space constraints.
What are your mods as of now? Do you have step colder plugs? I think your engine just being washed with fuel.
I'm not stock... intake and inletMe and Dan were just talking about what a Stock MS3 would put down. My guess was 230-235 WHP.
and I just realized Tylers was stock...right...I didn't know what your numbers were till now!!!
So Dan there you go:
You got about 50 HP over stock.
Just in time to **** the s*** out of Dan's car. (hump)Power-wise... intake, inlet, test pipe, tmic, bov
Step colder plugs would be a waste right now with it running so rich- but that's definitely on the to do list.
None of this surprised me, really. I just didn't expect to see the symptoms so prevalently. In the coming weeks I'll be adding some things on to lean it out (downpipe, fmic, exhaust mani), and by winter will be fully bolted with meth, should be sitting happily around 300-320, just in time to deal with a foot of snow on the ground.
