Post The Best Pictures of Your Mazda
yeah those wheels look dope. i was thinking about some other oe mazda wheels to rock and i forgot the new mx5's have the same bolt pattern as the proteges;)
yeah, same offset too. the only problem was the contour on the inside of the rim didn't quite clear the front calipers. had to put in some small spacers.
btw- to check the fitment i put 1/4" thick washers over the studs as make-shift spacers. seemed to work fine... is that sketchy or acceptable?!
yes, where the spacer would normally go. anyway, it worked well to check the fitment... but i have real spacers in there now!
