Since we're in full thread jack....
Car weighs 3100 pounds full of fuel, w/o driver. Dragstrip certified scale.
Accelerometers? I have an older G-tech Pro. I can move that mph around 5-8 mph easily just by playing with the car. Is it really going 5-8 mph differently each time? Nope, again dragstrip verifies it reads more than 1 mph high, that's for sure, more like up to 8 by my testing and, it always reads high. ET's a bit more in the ballpark of dragstrip experiences but, mph is way off, most of the time, even though G-tech made the same 1 mph claim back then.
Useful as a tuning aid, to a degree but, like the dyno, best not make bragging points out of the absolute #s.
The short answer is reliability... the K04 with the 5mm shaft is never going to push that much power as easily as the upgrade.
The idea is to bolt on a reliable upgraded snail that can better make use of all the other mods you are going to install or already have... no matter how you cut it this turbo flows more than the K04 - so if you wanna turn up the boost and exceed BNR's specs - and your willing to take the risk; then have at it.
weight....w/out my fat ass
This is exactly what I did to my MKIII Supra turbo. K04E upgrade in the stock housing. But it only cost me a couple of hundred bucks to have a local turbo specialist do the work. In fact, it was his idea to upgrade- I was just there for a rebuild.
Mind you, this guy was well beyond the R&D phase for the Toyota unit, so he could churn them out quickly at minimal expense.
Could be a good option, especially for those who want to upgrade & either not blow the warranty, or just get some stealth power nobody will spot under the hood.
How would this not potentially affect the warranty? You don't think the dealers would be able to figure this one out the minute they take a look at the computer? This turbo would be doing something very different than an unaltered stock one.
Yep, tough to imagine bolting a stock downpipe to your new big turbo and, I expect the wastegate actuator setup is proprietary to the MS3.
Would you give a little pro and con? also there is some adjustment on our acuator rod isn't there? any one played with it?
