COBB AP or ETS TMIC
orrr you can get everything and then get tuned? either way its the same at the end
but the end isnt whats important. its the short runso therefore you make it to the end. i will not put a dp, fmic or any other mod on my car that should have a tune.
so its not the same in essense or atleast in my eyes its not.
my car has never spiked
how do you like the ETS TMIC? how was the install? should I get new tubing?
http://www.mazdas247.com/forum/showthread.php?t=123646848&page=187
I love this thing. Car pulls and responds better. On avg, my boost temps are 3-5*F cooler than the stocker in all conditions. No need for new tubing. The stock ones fit fine with the ETS. The install was very easy. When putting the new one on, just make sure not to loosen the bushing/gromets while seating it in...especially the rear. Easy trap to loose them on top of manifold and below. But worth the money indeed.(drive2)
thank you for the input Mr. Mazda
Hmm hopefully I will have this new part in about a month or soo
NP...when you do get it and it starts to get really cold there, get the boost cut defender. You might get some because of the cold. But thats about 3-4 months till then.
Our ECU is very adaptive. Keep that in mind. Bunch of people using MBC's or running untuned without problems.
true true.. id only do top mount if i had that after market hood tho with the mean angry scoop.. if u want performance tho id do frount mount.. i hear its a little better then upgraded top mount not alopt better but a noticable diff.
at peak performance according to dyno results posted here in these forums FMIC / TMIC are very comparable. Only differences would be that with FMIC you get slightly more turbo lag which doesn't hurt much with the tiny fast spooling KO4. The main issue is heatsoak. The upgraded TMIC will shed heat fast but it will heatsoak if you sit at a light for a couple min or wait in line for your turn at the track.
If you have the money and have the time to install it then I say go for the FMIC. One of the perks of the TMIC is the fast install / removal. Just weight hte pro's and cons and make your choice. Either way you will be happy.
I believe dyno comparisons between the FMIC and TMIC is "dumb" because in both cases the hoods are open and there are giant aimed fans that blow on the motor + intercooler. In real driving situations, FMIC will receive much more air flowing through it and will yield noticeable more hp/tq. Another downside to FMIC is road debris, if you don't have a screen or some sort of protector, your FMIC could possibly get *****...plus the TMIC can be easily swapped in case of dealer visits. Go with the top mount... SLEEPER
Im going to get the TMIC first!
wow I didnt realize many more people posted after mr. mazda! thats what I get for not refreshing the page!
I'll second (or more like 8 billionth at this point) the changing of the avatar. Nothing screams complete tool more than a self-shot look at my mussculz pic. No offense bro but... 99.9% of us on this board are dudes so... who exactly are you trying to impress?
Anyway... nuff of that. TMIC all the way. I've got both so I feel I'm a good judge. Is an AP going to help you with heat soak? Is it going to actually INCREASE the overall reliability of your car like an upgraded core will? Not only that but... without any major mods (like a TMIC) an AP is relatively useless imo.
noone, I jsutn wanted to put that because I can lol..
But Im waiting till next pay check to buy my ets tmic and pg turbo inlet! im pretty excited about it!
FWIW..With my mods, I put down 254hp/272tq this past saturday. Woohoo!
