mazdasp33d
- Mazdaspeed 3
Since I have a car with mods should I ask the dealer to put in a different oil then they normally do? or does it really not matter?
they glance at your car and say "looks good!" and collect $300 from youwhat are you getting done with you "10k mile service" exactly and how much are they charging you?
dude, don't waste your time and money on this. go to walmart and buy some rhino ramps ($40), 6 qts of pp 5w30 ($26), oil pan ($5) motorcraft filter ($5), filter wrench ($5) and lithium grease ($5) assuming you have a basic socket set.
if you can mod your car, you sure as hell can change the oil.
Every time I change my oil, I take a picture of the receipt held in front of the gauge cluster to show current miles and I highlight the date on the receipt. This has never not worked for me.And also they'll void your warranty if you can't back up with receipts that you had your oil changed at an autorized place every 7500 miles, Jiffy Lube, Grease Monkey, etc. So even if you do a flawless oil change, a week later your engine could blow and warranty won't cover it because you did the oil change and not a "professional".
