shane02pro5
25ish_psi
- New Caney TX
Blacked out headlights, yellowed out fogs, hd lip, painted grill red and put the chromy m back on pics tomorrow since it rained today.
Ani cleaned up the interior...
I <3 the black face cluster in my P5.
can you pm how you painted the inside of the centre dash bit please? Im doing this to mine and need some tips!
Cheers
Marc
Don't tell me that magnum about the problems with wedge brackets. After lookin at bracket it doesn't look like it matches either. Where did you get the hex bolts btw? I'll be needing some myself to complete my install...
I actually like the new height. I'm guessing you added spacers between the brackets and the sliders or between the sliders and the seats? Just looking at the brackets from Wedge I don't see any way you could put spacers underneath them. Either way, I'm going to ride around like this for a while and if I find I don't like it, I may look into spacers.nice. i hated being that low. made driving annoying.. that's why i put the 1" spacers in.
All things considered, it could have been much worse. At least the bends were all in the correct locations. I just had to take a dremel and drill out the holes a little. 1/8" at the most. As for hardware, I re-used the bolts for the bracket/floorboard interface but for all the others I went to Lowe's. The thread/pitch is M8x1.25 for all bolts and I find you can't use traditional hex head bolts because the head is too big to fit inside the sliders. I went with some allen key head bolts and everything worked just fine.Don't tell me that magnum about the problems with wedge brackets. After lookin at bracket it doesn't look like it matches either. Where did you get the hex bolts btw? I'll be needing some myself to complete my install...
its a t3/t4 as well
Thanks, How is your build goin?
