rx8 rims
hey dudes. Will the RX-8 18x8" rims fit a p5? the offset is 50. same bolt pattern. been out of the loop a while, wanted to see what you guys thought! thanks!
I've seen P5's with those wheels. Definitely a good choice of good looking wheels
It will fit, Roll your fenders though, And are you lowered at all? If i was you I would go with Coilovers just because its easyer to adjust.
bought them last night. they are 18x8 with 50mm offset. even without tires on them i can see they won't fit. they are right against the lower part of the strut. literally making contact with the strut. no way they'd fit with tires on them. i'm bummed (cryhard)
That is negative. They will fit with a 215/35/18 tire and more than likely you'll have to roll the rear fenders.
Do a search for CrazeeD, he is running them in white on his P5 and many others have as well.
Yep you're right. Got my 215/35 put on them and they fit fine. I dunno what I was looking at the first time. Guess I didn't have the wheel on straight. I'm getting old.
Now to decide which springs to lower it. Coil-overs are $$$$$$$.
