Current Engine bay pics everyone
what do you guys use to keep your engine bays clean? mine is dirty as hell and i'd like to clean it up
I need to clean my engine bay. on a side note about engines, does everyone elses pull fan(pulls air into the engine bay) blow extremely hot air into the engine bay? Is that signs of a bad radiator? End threadjack
It's not extremely hot but then again it isn't like A/C. You have to consider when engine temperatures are nearing 200 degrees, 100 degree air is considering cooling. Hell, I work in the aviation industry and we use 1000F air for cooling!
okay cause when i had the hood up when i got home i held my hand in front of the fan when it turned on and it freaking burned to hold my hand there
You sure it was fan air and not just air moving from the belts? Also, it could just be that the air is already absorbing a lot of the heat. Were you sitting in traffic for a while before you did this? Radiators, like intercoolers will start to loose their efficiency after sitting and running for a while.
I drove 45 mins home. reason i checked is that it seemed my fan is always running. end threadjack
Nice man, If you steamed cleaned the engine it would really shine since theres alot of grease around everything. But thats all you would need to do. Looks good!
