Here is my engine as of today. A lil dirty but it is my daily. Only things new are the SU motor mounts and 626 intake manifold.
what do you guys use to keep your engine bays clean? mine is dirty as hell and i'd like to clean it up
It's not extremely hot but then again it isn't like A/C. You have to consider when engine temperatures are nearing 200 degrees, 100 degree air is considering cooling. Hell, I work in the aviation industry and we use 1000F air for cooling!I need to clean my engine bay. on a side note about engines, does everyone elses pull fan(pulls air into the engine bay) blow extremely hot air into the engine bay? Is that signs of a bad radiator? End threadjack
You sure it was fan air and not just air moving from the belts? Also, it could just be that the air is already absorbing a lot of the heat. Were you sitting in traffic for a while before you did this? Radiators, like intercoolers will start to loose their efficiency after sitting and running for a while.okay cause when i had the hood up when i got home i held my hand in front of the fan when it turned on and it freaking burned to hold my hand there
I am Update my car ok...
looks very nice
nice msp03.5
lil dirty..lol very funny! Nice bay bro.
