Well I finally got around to installing the magnaflow 14616 resonator in place of the second stock renonator. There is no more drone! car is much quieter. You can still hear it outside, but its so much quieter inside. I'll post pictures as soon as I can.
Uh, unless I am mistaken the 14616 is 2 1/2 inch on the inlet and on the outlet side. Our stock exhausts use 2.8 inch piping, slightly larger than 2 3/4 inches. That is really going to decrease your exhaust flow. And it is a muffler rather than a true reso, if I read the catalog properly.
Did you have to fit the 41616 inside your pipe where the second reso was rather than over the pipe to make it fit?
It's great to know you tamed the drone. That is huge. I sure hope I am wrong on the pipe size. If it's only 2 1/2 inch in diameter for the center pipe, hopefully you did not hurt your performance too much.
