New BC Suspension Install
Awesomness, I'm looking into getting a set before this spring.
i picked these coils up and just waiting to finish up the motor and ill be installing these. I was reading you OP and noticed that you changed from 560lb/in to 616 lb/in. is that something you did threw BC or is that something you can adjust on the coils? If this question was asked before im sorry im asking it again theres just alot of posts haha.
i THINK you select that though BC themselves, i don't think its adjustable.
LOL no, you can't just simply change the spring rate by turning a dial. You have to order different springs.
lol.....when ordering new springs do they have to re valve the struts? And would this bump up the price ?
when you order them, they are valved to go up or down another 2 kg/mm. So, with mine ordered at 10kg/mm I can go as low as 8kg/mm or as high as 12kg/mm. I actually haven't put the 11kg/mm (616 lb/in) because I haven't really had a need for them.
(hear ya)
i didn't think the Ksports had rear camber plates. I know you could change between two positions with the screws.... got a pic?
thats what it is only though. not really a camber plate but still get like some camber.
Mine are now installed, alignment done with FD rims, 5mm spacers and 245/45-16 Kumho V710's.
LF -2.6* Camber 0.00 Toe
RF -2.5* Camber 0.00 Toe
LR -1.2* Camber 0.00 Toe
RR -1.2* Camber 0.00 Toe
agh they must have typed that manually. they wudnt touch my camber cause there was no OEM spec. I asked to set it to 0 or make it even.
where did u go?
