independent fog lights
MS3 GT
ms3
i got a question for those who had indenpendent fog on our speed's. i just recently got it done with just running the wire through the fuse box under the hood next to the battery. i found out that fog will turn on itself. it did happened the first night when i just got it done. it was on at the middle of the night, when i went outside i just open the door and locked it then it went off after few seconds.. so today it came on again, so i decided not to open and close the door to see if it will turn off it's own.. unfortunelly it didnt turn off itself. so i opened the door and locked it....same result it wont shut off at all. so i turn the ignition to on and turn it off...will then it works :bs:. this is the 3rd it happened . first 2 times it went off it's own but the third time it didnt. so anybodys with independent fog have this issues?? could anybody help me with this i got the sport model....any helps will be greatly appreciated!!!!!
jw...what are independent fogs?
did you use a wiring diagram when you attemped to control the fogs the way you wanted to?
double check your connections
