just make sure its a merge collector (will have a neat "star" shape when you look inside), merging using 15 degree bends.Gah...more money being spent, maybe. Was talking to my local go-to guy when it comes to welding, and for the money being spent and the "return on investment", I'll probably just go with a better collector...probably a 200$ job (which would essentially double the cost of the header, but that's fine if it adds a few more ponies compared to what it can normally do, especially with what I'm throwing at the car).
head work will free things up a bit, and $650 doesn't sound like a great deal of money for a decent amount of head work - just make sure to get before and after flow bench data, to prove that it actually has made an improvementThe next thing he talked about was headwork. His "stage1", as he has worked on Proteg heads before, would apparently get me ~10hp in the midrange, and at least 5 in the upper range. 650CAD is what he quoted me for ~20 hours of work which includes a PROPER port&polish (might need to talk to him about doing a wee bit of work on the intake manifold...more convos to come with him for that) and some combustion chamber work.
personally, i wouldn't rev anything with the stock rod length to 7500 - but if you had to, the pauter rod would be strong enough to deal with the forces. forgies are normally heavier as more material is used and they are made to be a lot chunkier than the stock rods.Further question. I won't be going with the custom rod/piston combo, but if ever I wanted to up the RPM range a little (say to the 7500rpm range), better (read: stronger) rods would be recommended yes? If so, then any forged rod would be better then the stock crap...The question is, are most forged rods lighter, ~equal or heavier then the stock crap. Anyone know?
