^^^ This is what I did. I used some leftover silicone vacuum line and plugged it with a small screw and clamp. It's held for over two years with no problems yet.
blueprotegelx: if you are going turbo don't cheap out on your intercooler setup...a turbocharger kit is not a cheap endeavour, but running a cheap ass intercooler kit kinda defeats the purpose...if you are already spending thousands for turbo now, then spend that extra two to three hundred to get a proper turbo kit and make it look nice, ya know?
it'll work, yes, but the difference between making it -work- and making it work -well- is not that much, and intercooling is the best place to make power with a turbocharger setup on a small turbo like this
buuuuuuuuut I don't know if you need one or two ebay kits to make it work though
and btw, it's neox not neon =P hahaha
+1 that's what I did on my buddies p5 about a month or so back, worked fine
I had my MSP manifold for nearly two years and I had not a single crack and I bought it second hand. It all comes down to whether you have upgrade motor mounts or not. The stock MSP oil feed line is indeed a braided steel line, it just has a covering over it. IIRC, it's a -3 AN line as well and is perfectly sized for the turbo. If you're going to run a -4 AN feed line and use a ball bearing turbo I'd higher suggest the use of an oil restrictor to keep oil pressures at the turbo down. If you make your own lines to use make sure you use quality fittings like Earl's as the other will break and/or leak.lol msp manis crack like crazy, and the s and j pipes flow horribly...i dont have any experience with the stock lines, but the braided ones work great too... dont be afraid of aftermarket parts
as per the writeup
10psi is the max, or 250 whp (which is pushing it to be honest)[/QUOTE
ok thanks ya i figured pushing it past 7 on stock would be bad
