you should shut his wang in a door....and then see if he pees in anymore gas tanks
Here is my .02 cents. Knock the Kid out. Duck Tape him to a chair, Take his ass to the roof. Tie a Cender Block to a rope not quite long enoth to reach the ground. Tie the other end to his dick. Then wake him up and Drop the Block.. Problem Solved
Wouldn't it just be easier, and more poetic to leave em on the sidewalk and instead of a cinder block tie the other end of the rope to the back of your car and take off?
I don't know that I is but I think that given the enormous amount of legislation regulating fuel refining and additives it's an incredibly safe assumption to make. It's kind of odd to compare fuel additives to piss because you know, fuel additives and the refining process of fuel are federally regulated where as piss is not and is also an act of vandalism so basically your analogy is pretty... uh... ridiculous?
Urine is mostly water. Do you know what happens when you dilute a 14.5 gallon tank of fuel with 8 ounces of water and then run your car on it? Nothing. Sweet **** all. This is not the same as fuel additives or tank after tank of bad gas. Your analogy is bad.well sir, maybe u will find out one day for urself if u ever take apart a motor and see what ur internals look like after years of pumping bad gas into ur tank
HAHAHA! Best prank ever. I assume you know this from experience.make a police report, call your dads lawyer, make him pay.
afterwards, find out where he lives. Take a thin baking pan, spray some pam, pee on it until it fills to the top. freeze it. once it freezes up, take the tray to his dorm, take the frozen pee off the pan, and slide it underneath the door.
i love pranks.
