piss in gas tank
jlocurto
2008.5 Black Mica Mazdaspeed3 Grand Touring 7/15/08
so, just as the title says someone pissed in my gas tank.
here's the story...i go to school in westchester county, ny, and my friend on campus has another black ms3 with blacked out emblems and one of the RAs saw someone pissing in "his" gas tank, so he wrote the kid up and all that bulls***, but it turned out it was MY ******* car.
the ******* kid took a key to pry open the gas tank door, so its ******* scratched up too.
i know that this is not good, im heated and want to kill this mother ******, but what are the problems that i can run into with this bulls***? since i did drive my car without knowing the piss was in my gas tank...
So you have the kid's name? Sounds like he'll be footing the bill regardless. Lawyer time.
it's gonna be about the same as having water in the gas tank....you're gonna need to clean out the gas tank and and clean the fuel system....and i would go to the ra and get the kids information and make him pay for it....it could be hefty
you cant exactly drain these gas tanks either. Your best bet might be to remove the fuel line going to the cam driven pump and the connection at the firewall and run a hose into a bucket or something to hold the gas. The next part will take a little more work, figure out a way to jumper the fuel pump directly to the battery, there should be a relay for it under the hood
So was this a random pissing, or was he targeting someone? Either way since you have a name & a witness, I say it's time to lawyer up.
make him pay to have everything drained and cleaned and then make him buy you a new fuel pump, turbo, exhaust, an AP or SB, new wheels, CF hood, suspension and upgraded brakes then kick him hard enough in the nuts to explode his testes then ask him if he would like to do it again...
how the hell is your wee small enough to fit in a gas tank~!
Thats what i was thinking unless he was pissing from a distance, but then how does he open that lil flap thats inside. or do u guys not have that. really it seems like its too much effort.
What did you do to piss this guy off? Sounds like some bad karma to me.
Is a little bit of urine really going to **** up your car that much? I can't imagine a few ounces of piss having that much effect on 3 gallons of high octane fuel.
First of all it isnt going to do anything to your car. The ammount of urine that got into your tank is probably trivial. Second, why the hell are you not pressing charges? You obviously have a witness and should simply call the police. Once he has been charged then file a civil suit for damages if any. Honestly I am sure you have done worse to your car at some point. Get some Heet gas treatment for water in the tank and call it a day. that is strange though!
