AFC-SplitSecond PSC1 Map Library
ok question i recently installed some 440's do i have to pull fuel right before it gets into boost? for some reason it bogs real bad right as im about to get into boost once i hit 1psi it goes away
over pressure is -1
That's a bit early. Which map did you load? Try this map. The Over pressure is set to 1.1 psi. It should work for all proteges with 440cc injectors in vacuum. You'll need to fill in the 2psi - on map settings from any one of the posted 440cc maps as I left that unchanged.
Do you have a wideband?
Let us know how that works for you.
i only ran my map for one night then one of my wrist pin start tapping so i haven't drove my car since till i get my built block in, in a few weeks
what really sucks is i thought it was my rod bearings so i pulled the engine out last Saturday put new bearings in it reinstalled on Sunday started it up noise was still there
Afc V3 is now installed with the supermap for now..and to be honest, I don't feel any difference!! If I look at my wideband, I especially don't see the Afc kick the car into open loop at 1.1psi..knor at 2-3-4-5 psi. It kinda does what it use to do "stock"...which is, open loop kicks in at 4.5k rpm. Btw I'm only boosting 7-8psi.
Eveything is hooked up right...checked and reloaded the map 3 times. All settings are good, the only thing I haven't done is reset the ecu each and every time I reloaded the map. I can't see that making any difference.
Any comments or suggestions would be great, thanks!
