FS: XEDE w/ Plug and Play harness
Status
Not open for further replies.
BlackMS6
FS: XEDE $550 shipped
NEW PRICE!!! $550 shipped in the US!! UPDATE POST #23!!! NO MORE PNP HARNESS!!!!!
I have an XEDE from protege garage. It retails on there site for $899.99. I would like to get $550 shipped to your door anywhere in the US.
Here is some information on the xede from pg's site:
MazdaSpeed6 Xede Dyno tested on a Mazdaspeed6 at 260 awhp and 300 pound feet of torque!!
ProtegeGarage's Mazdaspeed6 runs 12 second range quarter miles with the XEDE, a cold air intake and top mount intercooler, tuned to streetable and safe engine operating parameters. No other engine management system for the Mazdaspeed6 comes close.
ProtegeGarage is the exclusive distributor of the XEDE System for the Mazdaspeed6. The XEDE (pronounced "x-ceed") is the only user-programmable engine control system that works with the factory ECU for great performance and near perfect driveability. Every one of its functions has the resolution and flexibility to complement all factory ECU functions. The XEDE carries the tuning torch without inducing any compromise to performance or safety.
The XEDE is the most user friendly engine management available! The XEDE comes pre-programmed for your application.
How does the XEDE work?
It is wired into the stock ECU. It intercepts signals to the ECU. For example, by intercepting the crank signal, the XEDE can advance or retard timing. By intercepting the load signal, the XEDE can make fuel mixtures richer or leaner. It remains under closed loop during idle, and goes open loop under boost. The XEDE also allows the user to control the boost levels.
Practical Information...
What is more practical than get in and drive? Forget tuning the car every time you drive it or the weather changes. Short of getting struck by lightening, the XEDE won't fail. It will be the most reliable piece of hardware on your car.
XEDE Technical Specifications
* 1200 possible adjustments
* 0.1% accuracy on MAF, MAP, and TPS adjustments
* 0.1degree accuracy on timing adjustments
* Fully sealed, rugged, and lightweight housing
* Support for hall and reluctor type crank and / or cam timing signals
* Support for analog or frequency MAF and MAP / load signals
* One additional 10-bit analog input
* One auxiliary digital input / output
* Internal storage space for up to 12 tuning maps
* Built-in boost control
* Self-configurable load axis, input and output variables, adjustment range, and math function for each map
* 'Map Select' input to change between one of two unique tuning maps
* Bi-color status LED
* Wideband Integration
stupid economy!! i would defin pick it up if my job wasnt slowing down.. if u still got it in a while i might be able to swing it.. gl with the sale tho!!
Thanks! BUMP!!
Anyone whos really interested pm me and ill give you a special price.
Status
