jsthomas00
Does anyone know if the Audiovox mini XM tuner will work with the Mazda sat ready audio system?
Yes. There are 3 ways to connect.
1. You can connect it by using the supplied FM transmitter through the radio.
2. You can connect directly using the aux input in the console if you have one.
3. You can connect it directly into the aux input of an I-POD adapter like the Neo Pro Link.
I don't know if others like the Dice or the Grom also give you an aux input option.
I have the Commander MT in my 2007 MS3 GT.
It's connected through a Neo Pro Link with the aux input.
My Xm receiver is mounted in the ashtray.
So with the door closed you can't tell it is installed.
