Any photographers in here?
^^ hahahha at the 2 pics.
interesting....no exif so you must have "saved for web" or some other version of saving the original photo.
one problem might be is that you should try and overlap the photos more...Thats a lot of land to cover on 3 photos.
other than that we cant tell much without the EXIF data.
Weird...
works perfectly on flickr.
Same data for all three pictures. I'm pretty sure Glen is right and when I turned, the light source came from a different direction and caused the light meter to change the WB? and threw them off.
Also, these are straight off the camera. I do not "save for web". I shoot in Raw+jpg mode.
Camera: Canon EOS Digital Rebel XT
Exposure: 0.001 sec (1/1600)
Aperture: f/2.8
Focal Length: 60 mm
ISO Speed: 100
Exposure Bias: 0 EV
Flash: Off
File Size: 2.7 MB
File Type: JPEG
MIME Type: image/jpeg
Image Width: 3456
Image Height: 2304
Encoding Process: Baseline DCT, Huffman coding
Bits Per Sample: 8
Color Components: 3
Orientation: Horizontal (normal)
X-Resolution: 72 dpi
Y-Resolution: 72 dpi
Date and Time (Modified): 2009:01:05 14:57:34
White Point: 0.313 0.329
Primary Chromaticities: 0.64 0.33 0.21 0.71 0.15 0.06
YCb Cr Coefficients: 0.299 0.587 0.114
YCbCr Positioning: Co-sited
Exposure Program: Manual
Date and Time (Original): 2009:01:05 14:57:34
Date and Time (Digitized): 2009:01:05 14:57:34
Metering Mode: Multi-segment
Color Space: Uncalibrated
Focal Plane X-Resolution: 3954.23341 dpi
Focal Plane Y-Resolution: 3958.762887 dpi
Custom Rendered: Normal
Exposure Mode: Manual
White Balance: Auto
Scene Capture Type: Standard
Gamma: 2.2
Macro Mode: Normal
Self Timer: Off
Quality: Fine
Canon Flash Mode: Off
Continuous Drive: Continuous
Focus Mode: One-shot AF
Record Mode: CR2+JPEG
Canon Image Size: Large
Easy Mode: Manual
Digital Zoom: None
Contrast: +1
Saturation: +1
Sharpness: 1
Metering Mode: Evaluative
Focus Range: Not Known
Canon Exposure Mode: Manual
Lens Type: Unknown (-1)
Long Focal: 60 mm
Short Focal: 60 mm
Focal Units: 1
Max Aperture: 2.8
Min Aperture: 32
Flash Activity: 0
Flash Bits: (none)
Focus Continuous: Single
Zoom Source Width: 0
Zoom Target Width: 0
Photo Effect: Off
Manual Flash Output: n/a
Color Tone: Normal
Focal Type: Fixed
Focal Plane XSize: 23.04 mm
Focal Plane YSize: 15.37 mm
Auto ISO: 100
Base ISO: 100
Measured EV: 7.12
Target Aperture: 2.8
Target Exposure Time: 1/1614
White Balance: Auto
Slow Shutter: None
Sequence Number: 0
Optical Zoom Code: n/a
Flash Guide Number: 0
Flash Exposure Comp: 0
Auto Exposure Bracketing: Off
AEBBracket Value: 0
Control Mode: Camera Local Control
FNumber: 2.8
Exposure Time: 1/1665
Bulb Duration: 0
Camera Type: EOS Mid-range
Auto Rotate: None
NDFilter: Unknown (-1)
Self Timer2: 0
Flash Output: 0
Canon Firmware Version: Firmware 1.0.3
Owner Name: Steve R
Serial Number: 3520738727
Canon Model ID: EOS Digital Rebel XT / 350D / Kiss Digital N
Num AFPoints: 7
Valid AFPoints: 7
AFArea Width: 189
AFArea Height: 188
Original Decision Data Offset: 0
File Number: 698-9825
Bracket Mode: Off
Bracket Value: 0
Bracket Shot Number: 0
Raw Jpg Quality: Fine
Raw Jpg Size: Large
Noise Reduction: Off
WBBracket Mode: Off
WBBracket Value AB: 0
WBBracket Value GM: 0
Filter Effect: None
Toning Effect: None
Tone Curve: Standard
Sharpness Frequency: n/a
Sensor Red Level: 0
Sensor Blue Level: 0
White Balance Red: 0
White Balance Blue: 0
Color Temperature: 5200
Picture Style: None
Digital Gain: 0
WBShift AB: 0
WBShift GM: 0
VRDOffset: 0
Sensor Width: 3516 (52-3507 used)
Sensor Height: 2328 (19-2322 used)
Black Mask Left Border: 0
Black Mask Top Border: 0
Black Mask Right Border: 0
Black Mask Bottom Border: 0
White Balance RGGB Levels: 2755 1016 1022 1400
Color Temperature: 6101
WB_ RGGBLevels Custom1: 2686 1020 1026 1345
Color Temp Custom1: 6203
WB_ RGGBLevels Custom2: 2403 1020 1026 1507
Color Temp Custom2: 5200
Set Button Cross Keys Func: Normal
Long Exposure Noise Reduction: Off
Flash Sync Speed Av: Auto
Shutter- AELock: AF/AE lock
AFAssist Beam: Emits
Exposure Level Increments: 1/3 Stop
Mirror Lockup: Disable
ETTLII: Evaluative
Shutter Curtain Sync: 1st-curtain sync
Compression: JPEG (old-style)
That's weird man. I'll have to fool around on my own camera and let you know what I do to get the results. But I do know this. CS3 has a better blending mode than CS2.
^ there is the reason for the differences between each scene
Posting images from Flickr will remove the exif data.
Oh, didnt know that. also, if I dont use auto, the WB is usually weird or off.
Even when I use the settings (Daylight, cloudy, etc) it seems weird. I've never been good at choosing the right one.
I guess I have to re-read all my photography books. I guess I skipped the WB chapters. Most of them suggest leaving it on Auto WB.
I shoot in RAW and adjust the WB in post processing. Previously, I used a grey card when I shot JPG but it became a hassle. If you aren't shooting in RAW, try it once. It makes post processing much easier due to the range you have with the exposure and white balance.
2nd attempt is much more fluid. You might want to try using the dodge/burn tool on the cliff section on the left to darken it a smidge.
I'll try the dodge-burn thing. brb(wiggle)
why are you shooting landscapes in F2.8? that explains why the picture is very soft ;)
you should be using F8 - F11
what does a tripod have to do with that? your shutter speed was 1/1600 at iso 100, you can easily handhold a shot in that lighting even at iso 100
You are correct. I'll try stepping down (up?) the f/stop next time. Is f/10 enough to get a scene like that sharper?
I just state it just for the fact of levelling things out like the horizon and such so he doesn't have to mess around with the pictures more than he has to.
Nutari: F10 is plenty good. Might want to even go higher if you want.
