ok I have to chime in on this thread!! So today I got back in town and met up with my car club/team and we had an install day at the garage. One of the guys mentioned how he had taken off his greddy RS bov and put on a new one (he wanted the HKS). Well I made a comment...we should see how it does on my car. Granted I've been running the Type-S KNOCK off since about May or so, with generally no problems. I was just not happy with the fact it was a knock off brand and the sound was sub-par IMO. So we got to messing around and I talked him into letting me have it...so what I did was install the Greddy RS on my car...I already had the adapter flange from the type s, so that worked out nicely. Now, he did not have the recirculation fitting, so we had to hook it up Vented. Well, normally I've heard of all the problems with this, but we messed around with it to see if we could get it to run right. So what I did was I went to advanced and found this plug. Its a metal cap with a bolt on the top and underneath is a black rubber donut with a metal piece on the other side and the bolt holding it together. I bought that, it was pretty close to diameter. So then I drove back, tried to get it to fit, to no avail. It was slightly too big for my recirc pipe. So then, I was messing with it and came up with an idea...and what I did was remove the bolt holding it together, and took out the black rubber piece and then test fitted the piece with out the rubber piece (just the 2 metal pieces with a bolt holding them together) and to my surprise, it fit right in the hole, snug. So i slipped in the first metal piece into the recirc valve, got it snug, then ran the bolt down the center. Then i put the other metal piece on the outside edge of the recirc pipe and ran the bolt through it and put the nut on the end. Then used a wrench to tighten her down, and it worked perfect. Then I started the car, and to my surprise...PERFECT idle...no stumbling...no surging...no noises....everything sounded stock. Revved it up and that some b**** growled and then blew off and went WAAAAAAAWOOOOOOOOOSHHHHHHHH with a faint whistle following it. DAMN it sounded great. Rpm's dropped back down to normal, had zero problems. So then I took it out on the street, dropped the clutch in first, roasted the tires, grabbed 2nd, chirped pretty good and that sumbitch pulled HARD. Didn't have any stumbling issues, no stalling issues, and no backfiring. On the drive back home, I even ran the heat on high while sitting at a red light, no surging idle and no stalls. The car is running great and I am sure it has to do with blocking the recirc pipe. I will keep everyone posted on how she does in the following days.
For the people who has done the Greddy RS...which is the best way to tune it (soft or hard) and can you provide a detailed description of how you have the set screw? I want to make sure I am spooling quick and hitting full boost...I noticed when I hit it, downlow, it seemed like it took a little longer before full power kicked in and I am sure this has to do with the stiffness of the spring. Any help, GREATLY appreciated!! But so far, I am very happy with the Greddy RS. Sounds and performs phenominal thus far.
