forget what i said about the tails. I am looking at parts for the bike now.
After the TL headlights and a suspension setup, Pro5 mods will be coming to a close
That was record time too! Damn, you're getting faster at changing your mind. Hell, I'd even go as far as to say you're approaching Woman!
i have a terrible memory. I had just remembered about the parts my buddy told me about lastnight.
And I ALWAYS have ideas. i just don't voice em. You guys would go nuts if i did.
Yeah...considering I had the damn thing in the house yesterday and dried it out with a hair dryer/silica gel pack.
Think my mechanic will overlook it during the inspection? haha
jeff, what happened to the headlight?
You are too much Tylor....lol Hey man, it's your money dowhatcahlike. And if the TL headlights and suspension are the last that's a nice way to go.
At first I thought it was due to the rubber boot partially popping off from all of the wires/rubber washer stuffed in there for the HID kit. Apparently though, the seal is shot from when they were painted. I did buy this set used off of another member and last winter they gave me no problems.
Definitely not 7 inches wide; I guarantee you that. They're either 6 or 6.5 inches wide, I can't remember which. I really want to say stock wheels are 16x6 +50mm with a 5x114.5 or (5x4.5) bolt pattern.
maybe i'm thinkin of the 17 i have on mine....my bad....i think it is 6"
Actually I just went out in the garage and measured them and from outside edge of the wheel to outside edge of the wheel(tire not included) they are 7-1/8" wide. That might not be where the width of a wheel is measure though, not sure
Considering that the stock tire width measurement is 195 (IIRC), I would also say that stock rims are 6". I think you should be measureing the inside of the bead, that should get you closer to 6".
Yah, I was measuring from the outside of the bead
Did the mazda alarm upgrade install yesterday without issue, works fine. Guess we'll see how long according to reports.
