since its VTA i seriously was thinking in your video it was from when you rev and then let off, your engine wants to stall and die because it's in vta mote and the engine does a little idle jump to keep itself alive and that lets out that baby whistle sound. I had that when i ran my type-s vta.
Just because I want to know, how does your run as vta because mine with the greddy type-s the car hates it and backfires to death, gives rough idle and wants to stall. Also what did you plug your recirc hose with???
As far as hooking up a boost guage, you can T into the part that goes to the top of the bov, just cut that and then T into it and the long single end of the the T will go back into the car for your boost guage. Run it through the hole in there firewall where the hood latche cable goes through
Thanks man ill have to keep that in mind. I was cheap and decided not to buy one of those block off fittings, so i went to Home depot, went to there plumbing department, and bought one of those screw in block offs for Steel piping. cost me all of a dollar and 27 cents, or sum thin like that.
Cool ill think about that when im hookign mine up. but as for the BOV vacume line, should i leave it at the stock location or move it closer to the waste gate and T off of the waste gate vacume line?
