used it to rush out and buy a new turkey. fridge failed to close completely=turkey spoiled
ordered a spec clutch stage 1+ and flywheel from protegegarage (thanks Ken) and today ordered new royal purple gear oil! whoot whoot cant wait
We drove it yesterday for the first time in months. I think I overfilled the coolant overflow tank because after I parked it when we got to my inlaws it started spewing coolant from the tank. Engine temp was fine and when the car cooled the level went back down....Drove it again today and it didnt overflow.
Hopefully thats all it was but its about time to flush the radiator and might as well replace the thermostat. Where do you guys usually buy yours?
Also, noticed some lovely oil residue coming from the valve cover. Is basic maintenance to tighten the bolts on the valve cover? Anyone know the amt of torque they should be tightened too?
How much does a new gasket go for?
not usually to tighten. all mine that have leaked were bad gaskets. the amt is in the inch pounts, like 20 or so, i have to look it up. its not alot cause the head will strip easy. its in the protege shop manual if u have it. if not i can check when i get home from work.
i remember them costing under 20 from auto stores.
yuh, I figured. after winter I'll have some maintenance to do on him then lol. new coolant and thermostat, oil and valve cover gasket....
installed the weapon r torque damper.
i dont understand why so many ppl in the past have disliked the quality and workmanship on this unit. it is very well made.
