Hahahaha here is the proof my intake is not plastic or PVC piping, I also paint it black, looks a lot better than white, let me know what you guys think...
Final Engine bay shots, looks much better in black...
What kind of paint did you use?
my turbo is tapped for my wastegate...but it isn't on the car yet, so i can't comment on how it performs...and i have a forge, so i shouldn't have a problem with the wastegate going out on me like people do with the stock unit...since there isn't a 'diaphram' inside of it.
I had absolutely no luck with my forge. its a nice unit but my boost would not hold steady at all. even with the help of forge for about a week. I put an atp on there and it held perfect. But forge said it wasnt their unit at fault so i sold it as is. I brought my thoery up to them and even for theirs they dont recomend it seeing vac.
Its a solid unit though (build wise).
no sir. i got the 626 so i have a spare as well (my stock one).
My thunder exhaust mani is cracked badly but i cant really take the car apart at the moment.
what are you plans with that 626 mani after yours is complete? ...if you're not going to keep it, let me know.
I have a thoery on why our internal gates go bad so fast. The diaphram inside the gate is meant to measure boost, but i think because we tap them off the mani, they see vac, so that diaphram is constanly getting forces from both sides. I think this causes premature wear. I know quite a few oem turbo cars use the turbos compressor housing for a boost reference. This way the WG only sees boost like it was designed for. I tapped my turbo and am still testing this but i cant really say for sure but its not an unfounded idea. it makes sense mechanically.
I know, I had your old MAM FMIC kit, remember ;) Sadly, even with the source for the wastegate actuator right off the turbo (it still is with my new setup) the actuator is still dead. Actually, the actuator has only even been in that position. I think, even with the source at the turbo, the actuator is still going to see vacuum (if vacuum persists in the manifold than it has to in the IC pipes as well). Perhaps A check valve is in order next time to prevent the actuator from seeing vacuum.
Now you have me worried about the Forge as well...
que? Im using the 626. I was just saying i have my stock one still as a spare. I was going to PNP and remove VICS or VTCS (cant remember which one) and maybe sell it (stock one).
aren't you going to be running one of your sheet-metal intake manis?
how will it see vac with the TB plate closed?
Like i said its a thoery. Im sure there will be some bad apples and variables.
theres quite a few who run the forge and seem to like it from browsing here. I think mine was bad and they didnt want to pony up. but its ok.
True, off-throttle, the throttle plate is closed but during most other driving conditions the throttle plate is partially opened and therefore there is vacuum in the pipes. Granted, the vacuum won't be as strong but it's still there. I might just try to put a check valve on my next wastegate actuator just to see if that does anything.
understandable, id imagine its a very very small amt or there would be alot more issues with turbos cause reversing the air at the turbo is really bad.
took it to get welding quote for larger inlet/outlet pipes on my turbohoses hotpipe and air intake pipe. Materials cost $15.00, labor cost $90 per hour, could take around 2-3 hours so looking at about $290.00 all together
Just got a quote for $35 in labor plus I need to buy the new flanges.
got my corksport strut bar on last night.
What did you guys do with the battery tie down and whatever that valve thing is on the left with the mitsu symbol on it.
you can tape off a vertical slit and leave it clear/white.
then paint the rest black!
btw, the intake looks good.
Damn, didn't thought about that option.. should i paint it black as well ? Thanks bro, I'm using Pipes from Dryer machine exhaust, cause i can't find any place here who can make me an intake that big.. good thing they are all aluminum
