I've had my ATP a long time, at least two years probably more, never a problem with it and it's had an external spring on it most of that time as well holding me at 10psi.
you CAN change WGA with out removing the turbo.
yea, but its a b**** to get the c-clip off with it on the turbo, even with as small of hands as I have lol
and its nearly impossible to get the c-clip back on without at least unbolting the turbo and pulling it away from the head >.<
it can be done, it's just annoying and almost easier to remove it (at least for me, I can pull the turbo assembly in an hour and a half now lol)
what I did to my msp today: removed the oil pump to send off to docB...then spent the rest of the day crunching numbers and researching the optimal turbocharger for my application...whoo! 25 psi here I come =P
I cheated when I did my WGA install. I removed the J-pipe, unbolted the mani from the head, and loosed that bracket bolt from under the car thats by the s-pipe. Then let the turbo and exhuast mani lean towards the rad a bit and reached in and replaced that little clip. Also I would just go purchase new clips becuae im 99% sure everyone will lose that little bastard.
On another bad note, I randomly tested my wastegate actuator and sure enough - it's shot. Now, its vacuum source is right off the turbo so a leak there wouldn't cause a problem. It does suck however because the ATP wastegate actuator is only 1 year old and it's already dead. This would explain why I randomly hit 14 psi a while back. Damn...
my atp lasted a few months, but i got it used. forge works great!
I would imagine since the diaphragm is located so close to the turbo/exhaust manifold, the rubber gets absolutely cooked.
did yall remove the small heat shield from the canister?
even with that dinky shield, the diaphragm sees extreme temps.
yea, thats exactally what I recommend to get the job done...a little more work involved, but youll probably save yourself a lot of headache and possibly time (ironically)
and yea, those little c-clip bastards suck lol
If it makes life easier to remove it then remove it! It might take a little longer but its worth it for a lot less stress during the install. If you feel yourself getting frustrated take a brake for an hour and go back at it!
what I've been considering today about the msp:
putting off finishing the msp....and buying a second msp as a daily driver so I can finish this one right...
Hahahaha here is the proof my intake is not plastic or PVC piping, I also paint it black, looks a lot better than white, let me know what you guys think...
Final Engine bay shots, looks much better in black...
looks good bro!
gah I can't decide, buy a second protege and put off finishing this one until I can save up the cash I need....or just deal without a car at all....the later isn't as easy as it sounds where I live >.<
looks good bro!
Thanks Neox, I'm trying to clean up stuff and make it look better, I'm waiting for a GReddy Pressure Sensor, and Pressure Sensor Harness i ordered from USA, according to my tracking number tomorrow at 9 am i should have it in my hands, I love DHL bro, 5 Business days shipping were not bulls***.. I need these parts to install my new Electronic Boost Controller, I really don't like that much using a manual one.. All of the sudden my GReddy Profec B Spec II got messed up, and is the unit, not the boost selenoid valve, I can't wait to install my new Toy,, I got from a friend of mine for free a Greddy Profec E-01, i just needed to order the missing parts mentioned above..
Well, no exhaust leaks when the car is cold but the idle is still irratic. Something must have happened between yesterday morning when I parked my car and yesterday afternoon when I left because I wasn't having these problems Tuesday night. My vacuum reading is still good but I know that even small leaks are enough to mess with these cars. The only thing I did was Tuesday night I cut a vacuum line shorter because there was too much slack. There are only about 3 other lines I haven't tested but I suppose it could be one of them. Any other areas I'm forgetting about?
I don't think I'll ever get rid of the turkey. I just had a HKS SSQV welded in and I still get a little turkey at low boost levels. It's using the brake booster as its vacuum source too. It probably has to do with the 8 miles of other vacuum lines I have under the hood.
I get a small flutter sound at low boost which will almost always happen cause your really not opening the valve fast enough. but ive never once had turkey. It must be a BOV thing. you boyz and your noize
Well I just went down and checked just about every vacuum line. The BOV holds vacuum as do all other vacuum lines I could check. I can't find any leaks and I can't imagine anything else has seriously changed since last week when everything was working just fine. The only thing I haven't checked is the exhaust but I'll do that tomorrow morning before I leave.
I have a thoery on why our internal gates go bad so fast. The diaphram inside the gate is meant to measure boost, but i think because we tap them off the mani, they see vac, so that diaphram is constanly getting forces from both sides. I think this causes premature wear. I know quite a few oem turbo cars use the turbos compressor housing for a boost reference. This way the WG only sees boost like it was designed for. I tapped my turbo and am still testing this but i cant really say for sure but its not an unfounded idea. it makes sense mechanically.
my turbo is tapped for my wastegate...but it isn't on the car yet, so i can't comment on how it performs...and i have a forge, so i shouldn't have a problem with the wastegate going out on me like people do with the stock unit...since there isn't a 'diaphram' inside of it.
