The cars been running like crap for a while now and this winter will be the perfect opp to get everything swapped out and fixed up. I'll more than likely be replacing the wga with a TPA, maybe the SMIC, both O2 sensors, and possibly the BPV. My main concern is the exhaust right now. When all is said and done on the front side of the drivetrain Ill be pushing almost 10lbs and I know the stock exhaust isnt going to be able to vent that kind of pressure.
From what I've read, the j-pipe seems to be the main bottleneck on the system, but does it need to be replaced or will a CB be enough? I really like the magnaflow CB, but I couldn't use it if I was to replace the S/J pipe and the cats because of its small diameter. If I had to replace the whole exhaust I'd probably just buy a high-flow cat(any suggestions on a brand?) and a HKS muffler and take it to a shop and have it custom made. In that case, would you trust a shop to fab up an S-pipe and/or J-pipe? What would I do about a flex-pipe?
