cucamelsmd15
- 2008.5 MS3
E-85 is a hoax. Much less power than gasoline and FAR more expensive to produce.
Um, wat?
105 octane, cooling effects of alcohol, and the fact that you can dump tons of boost/timing into a car running e85 says your wrong. A good tune with e85 will generally get you 20-30hp or more over 93 assuming you have the fuel system to support it.
