is 5w20 oil ok?
stageup
so i took my car in for an oil change @ the dealer, 2nd time.
first time they put on the paper, 5w30 6qt
today it said 5w20 5qt so i asked the service writer wtf
it should be 6qt's and 5w30. he said oh they just input
it wrong on my work order, the tech knows what to put in
the car. so i checked, the dipstick is full so i know they did
put 6qt's in. but is it ok to leave the oil in for now until my
next change? or should i change it again cuz the dealer
may have been lying to me.
i only went there cuz my first 3 oil changes are free.
Well fwiw my owners manuel says 5w20. I think all the first MS3 manuels came like that. THen all of a sudden people started telling me that theirs said 5w30. Either way for one oil change your good. I did my first with 5w20 then jumped ship to 5w30 synthetic.
No way I would run 5/20. It was changed by mazda for a reason! Many choose 5/40w even to protect against the excessive heat a turbo generates.
5w 20 is for the regular mazda 3. Mine was one of the first off the line 08/06 and it says 5w 30 for the ms3. Check your manual again. I think the dealer probably put in the correct stuff. I have gotten receipts that say 5w 20 several times. Now I just bring my own oil. Its cheaper that way.
Wouldn't you lose performance and put a greater strain on the motor and turbo (I know, not a lot, but its all relative) but running a thicker oil??
Dealers usually stock 5w20 in volume, so if they can get away with using it, they will rather than stock both types. It's bad business practice though and for me would be enough to never take my car there again...
alright, so this is my big thing, I want everyone that can to check this out for themselves and let me know if anybody else can shed some light on this issue. I had one oil change done on my speed3 by mazda and that was the first oil change at 1000 miles. They put 5w 20 in the car and I made a big stink about it because the manual says 5w 30. Their explination is that mazda changed the manual so the mazdaspeed3 should take 5w 20.
Okay, so here is where it gets tricky, My manual says 5w 30!! I go online to the mazdawebsite and go through the mymazda thing and download their manual for my car. It says 5w 20!!!!! and nowhere does it say 5w 30!!. It gets even more tricky here though, the newest models like the 2008.5 mazdaspeed3 manuals still say 5w 30!!!
I have always used 5w 30, not because of the manuals, but more because I have a good knowledge about cars and you should not be running any lower than a 5w 30 on a turbo car, unless you are living in northern canada where it gets really cold. I will be switching to 10w 30 once my car hits the 50,000 mile mark.
But if anybody has any info on this whole manaul saying different things, please shine some light!! Also, I don't think the dealerships are lieing to you, I do think that they are looking up the manual online and it says very specifically to use 5w 20.
Thanks but no thanks, I really only needed to check it the one time to know what I read. My manuel says 5W20 and I have a Speed3. My build date is 2006 as well.
really, yours says 5w 20? My manual says 5w 30 for the turbo. weird
Don't all the other DISI manuals say 5W30? I can confirm that's what it says for the CX-7 (all years)...
No way in hell would I use a 5W-20 oil in a high-performance turbocharged motor. This lighweight oils are for FUEL ECONOMY. You cannot tell me the engines built today are that much tighter than they were 10 years ago. However, emissions and fuel economy stardards are! I'm using 5W-40 Shell Rotella T Synthetic right now. I really don't care if I get 1mpg less than I did before with 5W-30. In the scheme of things, it's nothing.
Most of the UOD's show a 30 weight oil sheering down to around a 20 weight after 4-5k miles in this motor. Lots of people think this is attributed to fuel dilution, however you'll find that 'most' UOD's done on this car don't show fuel dilution being an issue. I'm sure different driving conditions can attribute to fuel dilution, ie: lots of stop and go, short trips, not allowing the car to reach operating temps, etc... I'm not concerned with my driving habits, as 80% of the mileage I put on the car is at 70mph on the highway. The reason why the oils are thinning is that they're running through a turbocharger that is heating up to 1,000 degrees F and spinning at 100,000 RPM at times. Years ago, manufacturers would give you a choice of viscosities in the owner's manuals and let people choose which oil to use depending on temps. Most of them overlapped. In the summer, I see nothing wrong with using a 5W-40 oil. In fact, the bulletin Neuspeed released for the K04 turbo says to use 20W-50 for the summer and 10W-40 in the winter. I don't know if I'd go THAT thick, but doing a 5W-40 in the summer and then back to the 5W-30 in the winter is my plan.
FWIW, my 08.5 says to use 5W-30 and the one online is the same. Maybe some manuals had typos? I can see the possibility of a tech putting 5 quarts of 5W-20 in the car. Regular Mazda3's outnumber MS3's by like 100:1 and I'm sure it's force of habit. If the receipt says 5W-20, treat it as such. I wouldn't take their word for it. They're just looking to make a quick buck and they're going to hear it from the manager if they find out they had to do another FREE oil change because someone F'd up.
Screenshots of the 2008 User's Manual from the Mazda USA website... FTW. My printed manual in the car shows the same.
Without Turbocharger: 5W-20
With Turbocharger: 5W-30
This concerns me also. How do you know the dealer is using the right oil, even if they say they are?
I have an oil sample for analysis from my last change and I'm pretty sure it's gonna show heavy in fuel based on the smell. Could this be a sign the dealer's using 5-20 vs 5-30?
I guess the only way to know for sure is to do it yourself or bring your own oil. Until then I'm just using up my free oil changes.
<snip>
Providing your own oil certainly helps for one; but the paranoid ones among us may fear the tech keeps the oil for him/herself and fills your car with the shop oil.
I guess you could be 'that guy' and insist on observing the oil change to ensure they do it right -- just don't expect a warm reception from the service guys.
That's just it. When you take your car for service ANYWHERE, you're putting your trust in their hands. As little of time I have these days to do my own maintenance on my car, I still manage to change my own oil and try to do most of the other wear items. I'd even go so far as changing my own brake pads because I just don't trust service departments. Sad, but true. If you've got a real good relationship with your service department/mechanic, then more power to you.
I've been changing my own oil in multiple cars I've owned for the past 13 years and I've NEVER drained a drop of oil that didn't smell like fuel. All oil is going to have a fuel smell, so I wouldn't be suprised if your oil comes back OK.
Even if you bring your own oil, you're going to have to physically stand there and watch them put it in to get a warm fuzzy. That would probably be a problem for some people who use synthetics, because some of these moronic service departments are claiming that Mazda does not recommend synthetics in a high performance turbocharged motor and probably wouldn't put it in anyway without voiding your warranty. Holy s***, hello! What kind of motor would benefit from synthetics more than this one???
