If the MS drive train or room for the drive shaft etc is identical or close to that of a Speed 6,can the MS front drive theoretically be moved from front to rear.Any ideas or possible inputs from an engineering point of view would be appreciated,of course weight distribution should also be taken into consideration.
Technically we would just need to replace the drive shaft and move the front set up to the back don`t we.I see a whole lot of possibilities and miracles in the horizon if this can be achieved with a moderate budget,using possibly ford focus derived spare parts or similar aftermarket components.
I think that this would be the first step to an ultimate power goal and a full remedy to an ever overshadowing traction problem for the MS.I`m sure all you MS fans and the world would drawl over a wide body MS with 295 rear tires and HP under the hood.
