- -- 03 P5 / 23 CX-5 --
Common metric bolt with 12mm head.......I used 3 different length ones with thick washers to pull it up flush. The longest first will get it going but bottom out in the hole, back it out & use the next shortest one & do the same thing. The next shorter one should pull it up flush. OR keep stacking washers on the same bolt. Whichever...........use some grease or antiseize on the pump shaft.
