Crypt0wind
- 2007 MS3 GT
When I turn left/right hard 90> at low speed (1-20mph) I hear a low audible whine from only the right front wheel. Nothing at normal corning speeds. It's not a grinding sound, but it almost sounds like a CV joint or bearing/wheel problem, I'm not sure???
Here's the problem I got a synthetic oil change, 75w90 synthetic transmission (30k service) at a oil change place. I got home <10 miles and cleaned my MS CAI and rotated my tires (DIY every 5K). I noticed the whine noise within a couple of miles of rotating the tires and CAI cleaning. So, I rechecked my lugs nuts with a torque wrench. Did the parked wheel turning to check the power steering pump.
Could this be a bad CV joint? Or is this a bad trans fluid change? Or did I mess-up when I rotated the tires?
