I've got sane dogs! Take one of mine!
LOL you don't live 10 minutes from me so I can return it when you're not looking though!
(actually, that wouldn't happen, but you know...)
So yes, where are we? The 'other' engine is totally torn apart, I'm more than likely going to have OPM Autosports in Cumming, GA (lol cumming) do the machine work on the block and head, and the maintenance on the head. I was marveling at the fact that the entire bottom end of this engine (not including the block and oil pan, but pretty much every damn thing else), in labled bags, fits in a 12x12x8" tupperware box. And the lid closes lol. For someone who's never done this before, there's surprisingly little there. I actually was taken back at the simplicity of the thing. We all know the principles of how an internal combustion works and all the components, but I guess for me it all seemed overly simplified until I tore this thing apart. You look at it and go 'nope... that really IS all there is to it' haha
This afternoon I finished up the work on the manual steering rack conversion. I took 'er out for a spin and it feels great! It's not very heavily weighted and feels really direct. I was actually surprised at how light it was sitting still in the garage. I have to say I'm very pleased with the results.
Only a couple minor issues cropped up... the manual rack had outer tie rod ends, but the dust boots were in crappy shape. Getting them off wasn't terribly difficult, but as the ring that seats the boot on the ball joint of the rod end is rigid, and makes for a VERY tight fit, getting them back on is best described as a royal pain in the balls. The problem is, it's nearly impossibly to get it seated using 'standard' hand tools. So, I figure I'd RTM and see if I couldn't garner any wisdom from the FSM. Well, there's a SST (special service tool) that's used with a press to get these things on. Great... now you tell me...
Now I have to go out and pick up one of these schfancy SSTs
And by schfancy SSTs, I mean a $0.56 PVC 3/4 > 1" PVC fitting. Because the fitting was smooth on the inside, it wouldn't risk tearing the boot like a metal 6 or 12 pt socket would. The 1" fits pretty much perfect over the boot, and the smaller 3/4" side fits over the stud on the rod end, and is an excellent surface for hammering
. About 5 minutes on the work bench and I had re-greased and re-booted the tie rod ends.
Also, during my 1st drive I noticed that the steering wheel was about 1/3 turn too far to the left. I mean... it
LOOKED like we had the rack straight when we put it on, so wtf? LOL. Oh well, lesson learned... put the steering wheel on once the wheels are on the car so you KNOW, not before. I removed the wheel, set it straight, and got it 99% right. Any other corrections can and will be changed via the alignment. My options were either a hair to the left or a hair to the right, so it's REALLY close.
In my short drive, the alignment didn't feel terrible, but I could tell it's not 100%. The toe is WAY out. I'm heading to GTE for that on Thursday. We'll see if they can't squeeze some more caster out of this thing. After they get that done, the only thing left to do is bolt the engine splash guard to the bottom of the car and autox it on Sunday (drive2)
