COBB RSB went on this morning. Posted a pic for comparison with the stock bar. Went for a little drive around the block, and even pushing the car 5/10ths around the turns, I noticed a big difference. Much more neutral and confidence-inspiring, and the rear rotates quicker.What did you use for the torque settings? I called Cobb today asking them, but I'm not real comfortable with the answer. My Ram's RSB torque specs were radically different between the axle brackets and the ends of the bar.
Just curious are you going to replace the front sway bar as well or just going to stick with the rear? Also any advantages to just doing the rear?
Adding a stiffer front sway bar is a no-no on a FWD car...I wouldn't recommend it. I'd stick with a beefier rear sway bar and call it a day.
What. are you sure? about front bar w/rear. The dampers are more than enough for stock and quite good for the Cobb springs, the h/r drop are too much for dampers and are really for appearance. I think you want coilovers A. But i have to question the no front bar on front wheel drive. Help me out on this .thanksAdding a stiffer front sway bar is a no-no on a FWD car...I wouldn't recommend it. I'd stick with a beefier rear sway bar and call it a day.
I'd also look into some new shocks and springs, but with the mazdaspeed 3 being sort of new, the choices are weak and limited...I don't like the springs from cobb, and H&R's are too low for the stock dampers.
would you please elaborate on this?
What is there to explain? If you knew how a sway bar works, you'll understand why it isn't smart to have a beefier front rear sway bar on a FWD car.
Let me explain, the stiffer the bar, the less traction you will get when turning.......meaning you will lose traction in the front end of your car...losing traction in the front end of your car on a front wheel drive is kind of....BAD.
The stiffer the bar, the less traction you will get when cornering, and not having traction or enough traction with a front rear sway bar on a front wheel drive car while cornering hard, will yield some very bad results.
That is all.
so in turn, a rear sway bar on a rear wheel drive vehicle would also be "bad?"
Big bar on the rear, stock on the front if you do no other suspension mods.
Stiff bar on the front tends to lift the inside front wheel, but stock bar, being softer, does not.
I ran the Hotchkis rear on soft setting last year. Great improvement in turn in response and no extra front tire spin. Oh, only about 2,000 track miles to base my opinion on.
Im trying to debate which to get either the Cobbs or Hotchkis.
Any insight? (gossip)
Get the least expensive one, cause they're all the same shiznit(braindead
