yes, I have them as well. I just installed them a few weeks ago.
I'm experiencing everything you have stated so far. Super easy install. I mean really, can it be any easier? lol
I measured everything before the install, and everything came out pretty even. I will raise the front as its a little low for me. The rear is fine. I need to go back and get a better alignment after I raise it up a bit. The 1st alignment I had was ok, but I need to fine tune it for my driving style.
Camber was @ -1.9* front with about 1/16 toe in.
Before I installed the BC's, I had 0 toe all around. I'm going back to this setting. The car feels much better to me with 0 toe.
As you stated, the ride is stiff but not bone jarring. My Tokico/Espelir set up felt more harsh than this.
Also, I too 'am looking for that lift throttle over steer that I once had with the traditional strut set up. When I 1st installed them, I noticed a very pronounced push when turning hard. Since I've had an alignment, its much better but I still need to do some adjusting. I will be playing with air pressures, alignment, and damper settings to find out what works best for me.
Funny thing I did notice. It seems with my car, the stiffer I go in the rear, the more body roll I get. Weird. I think some of it is the front Racing Beat sway bar. I really need to re-install the stock P5 bar.
Anyway, I appreciate your informative review and look forward to applying some of your experience to my new set up.
So, on to some pics...
