john blutarski
- 2004 Subaru WRX STI
You're suppose to always check your oil when the engine is cold, so no.
I thought so too but our owner's manual says to get it to operating temp, then shut off, let sit five minutes and then check it.
See, that's what I was concerned with. If you check the oil while it's cold, then all of the oil is in the pan and not partially covering the engine components which is going to incorrectly show a low level. So, you add oil which screws things up a bit.
In order to truly try and diagnose this issue (as much as you can on the web), then you have to figure out how the test is being conducted.
It's like trying to know when you're supposed to check your tire pressure. It's the opposite of this and should be checked cold. Wait....right?![]()
Doesn't the dipstick measure from the pan? Then it would incorrectly show a high level...
I've been changing my oil since day one... 6 full quarts of Red Line 5w-30 puts the oil level exactly on the full mark. Of course thats after letting the engine run and fill up the oil filter and check for leaks.
In addition, this engine seems to have a lot of places for the oil to hide and settle. When you change your oil, make sure to let it sit there for a while draining on a level surface...raise the front, let it drain a few minutes, lower, let it drain again, raise the rear, let it drain again...
I have left the car draining for about 30-40 minutes and oil just keeps trickling out...
So, if you are just draining the oil for a couple of minutes and then adding 6 quarts, its no surprise you get the oil over the full line since all the old oil has not been drained...
Just my observation on my personal experience with my MS3...
+1
6 quarts reads at least 1/4" above the max line on the dipstick.
I meant to check my oil level the other day and forgot and started the engine... The engine ran for a few minutes then shut it down, I let it still another few minutes and then checked the level. It was 1/4 below the FULL line. I was a little worried cause I thought I was burning oil...
The next morning, I remembered to check my oil before starting the car and it showed exactly at the full line...
Point of the story is that when you change your oil, make sure the car has sat over-night before draining the oil and make sure you get all the oil out.
If you drain your oil at a quick-lube place/dealer after running the engine, you will not get it all out since the oil will be puddling and sitting in nooks and crannies in your engine, thus resulting in an over-fill...
I've always let all my cars sit over night before draining the oil...
I've always filled with 6 full quarts and get to the exact full line everytime...
Just FYI...
That's funny. Actually, you will probably get more oil out if you warm the engine up before draining it as it gets thinner and drains more easily.
If you let the car sit overnight, the oil will be cold. Any oil puddling & sitting in "nooks & crannies" will still sit there no matter how long you let her sit...
I don't agree, cause when you park the car for the night, the oil is hot, so the oil will drain back into the pan regardless...
Sorry if this is a stupid question but for those people who show too much oil, are you fully heating up the car, parking it in a level place and letting it sit for a couple of minutes before checking the dip stick? Just wondering if the oil is still splashing around in there which may skew the results a bit.
You're right in that regard. The part I found funny was the oil "puddling" in nooks and crannies. Think about it. Any oil that puddles in a cavity is going to stay there, no matter how long it sits, unless it sits eons and eats a hole in the bottom of the cavity it's sitting in, then seeps out. It's like a quart of oil sitting in a plastic bottle with the cap off. It's not going to drain out no matter how long it sits on a shelf.
On the other hand, I didn't look it up in our owner's manual, but the manual's for most auto's I've owned stated to check the oil with the engine warm after letting the car sit for a few minutes to let the oil drain back in the oil pan. I don't know, maybe the oil expands when hot and gives a more accurate reading.
It might be interesting to do an experiment if one is so inclined. Warm the engine up to operating temp, park the car on level ground, shut off the engine, wait five minutes, check the oil level. Don't move or crank the car. Check the oil level again in the morning while cold. Report the difference, if any, in the oil level. Let us know what you come up with.
I would say, after over 40 years of owning/maintaining various cars, that the small difference you see, if any, will not matter enough to where it would cause you to have an oil level in your engine that would cause even the slightest bit of damage to your engine.
No worries...
I always use all 6 quarts.. It will read above the line when the oil is settled but if you start the car then shut it off it will show exactly level. I'm assuming that is how it should be. My car is an 06 MS6 with 26,000 miles ive never had the smoke issue... custom exhuast 2nd cat delete.
Are you saying right after you change your oil...? There will be an above full indication due to the oil filter being empty. Once you start your engine, the oil will fill the filter, thus leveling the oil level...
I always fill my filter with fresh oil before installing it... I don't like my engine to dry start...![]()
