Too close to call.
If it rubs, you'll only need to roll the rear fenders. Our cars don't have problems clearing the front fenders unless you run 225 or wider tires.
Really? That's surprising--but not impossible!JoshP5, check this out... It Fits!!!
No rubbing against the rear fender? Have you done the speedbump test with a full load of occupants?
maybe, what tire is it? If it something that runs a little wide, it'll probably rub.
Not even closewhat tire is it? Aren't all 225 width tires all the same width?
depending on how fat that tire is, it'll probably rub occasionally w/ passengers in the rear / over big bumps. I've got more or less the same set up, and it's very infrequent, but I'm usually alone in the car and not hauling a lot of cargo
