Honestly, and unfortunately unless you have a high performance, high output, engine, Intake and Exhaust mods really don't change much. Basically just make sure everything is in good working order before you take it into get emissions test. Slight tune-up maybe? Change the plugs and the filter. Routine stuff. Good luck with emission testing. You're lucky, I gotta get my '73 Nova tested before the end of the month and its currently not running and besides that it's got a high performance double pumper carb...no passing :/ lol
Ya unfortunately. But we have so much dust out here i don't see how it matters lolAZ still sniffs? That sucks! you don't even get tested in MO. Well, safety.
I believe he's talking about Mother Earth...not a mother in the car...
My understanding would be that the process of making the engine more efficient by using modifications is shown to work. If you maintain your driving habits while increasing the efficiency, or horsepower, or the engine, you would in fact conserve gas and decrease harmful emission.
Without any proof, or any real factual basis for my hypothesis, I would imagine it is possible. The following modifications could be made without creating an increase in emission, and could in fact reduce the emissions of the engine.
The wagner exhaust manifold, which keeps the primary cat.
A cold air intake
Cat-back exhaust would have no impact on emissions
Lightweight Flywheel
Change out 5th gear to reduce RPMs at cruising speed
Lightweight or Underdrive pullys to reduce parasitic loss
Nology Hot-wires to help efficiency of combusion
Engine management could also create higher MPG and better/cleaner combusion, although you won't pass California emissions tests.
Theoretically you could add additional Catalytic conveters to the exhaust to catalyze more harmful emisions.
So, I think you can definitely improve the performance without increasing emissions, but reduction of emissions would be very difficult or minimal at best.
A cold air intake
you'd think reducing emissions and increasing fuel economy would go together, but not necessarily. in-cylinder temperatures during combustion affect the type of pollutants created, and controlling combustion temperature to reduce pollutants does not necessarily correlate with increasing fuel efficency. I'm no combustion engineer, but I do know what goes on in a cylinder during combustion is way more complicated than simply rich/lean and timing. air temp, fuel temp, chamber shape, swirl, pressure, fuel particle size....
car makers balance economy, power, longevity, emissions, manufacturability, servicibility... and hope they create a product that sells, doesn't kill them with warranty costs, and doesn't result in EPA fines.
people who mod for performance are choosing to balance that equation differently than the manufacturer. you could just as well mod for emissions, but I don't think the aftermarket industry is putting much engineering effort into developing those products.
like p-funk said, keep it running right and drive reasonably.
ride your bike to work if you can. I cut at least 50% of my emissions that way.
