flux capcitor
Hi every one ! I just got the new MazdaSpeed 3 2008, I would like to get some Advice what is the first Upgrade you recommend me or keep it on stock ?
Something to keep you from grinding your teeth...... (motor mount) then CAI is a must mod . It totally changes the car . It does make it noisy though .
I may be wrong but I have talked with several mazda dealership techs and they said the motor mount issue was remedied on the 2008's! Is this true or is everyone still worried about it?
different mount all together the one that was breaking was the trans mount and the one people replace is the rear mount on the bottom of the engine.
Ok thanks for the info..I have a 2008 MSP3 (400 miles on her) so should I look at replacing mine, and if so, does anyone have a link I can use to get this part?
ok don't mean to step on any toes...but a Cold Air Intake? You make the air a few degrees cooler then it gets super heated in the turbo...hmmmdoesn't sound like the best "bang" to me.
Short ram Intake...make the intial breath easier, our airbox is rather restricted. If you want to make the air cooler the do the front mounted intercooler (cool the air after it has been heated and compressed) then you run into another problem increasing lag....so now you need a bigger turbo....etc etc etc...
the real solution...make our car about 5-10K cheaper, so that as soon we get it we can "top to bottom" the engine and drive train.
(lol)
Anyway, don't understand what you mean about grinding your teeth, but if he does upgrade you will be grinding your teeth. If you are not going to mod the s*** out of this car like I have, then please do not upgrade. There is no need. If you do decide to upgrade the rear engine mount, go with a 70 duro or less. Do not get the 88.
Anyway, CAI would be the best thing for now. You will be able to hear the turbo spool alot more though. Don't know if you still want to keep the car quite?
Good luck.
they are not dogteeth if they were you would hear a whining noise in every gear like reverse.
