It is always nice when an install goes as planned. Glad Curt was able to help you out without sending it back.
With your bare hands - Nice.
Cheers!
Peter
	Man, doing this kind of s*** is just plain dumb. This vehicle isn't rated to tow anything, and the load limits on the vehicle are somewhere around 850 pounds. Not only does this assume that the total load will ONLY be suspended BETWEEN BOTH AXLES, but it assumes that the total load will be SPLIT between two axles. You're going to overload the back axle of your vehicle doing stuff like this, and if you ever haul 4 people plus bike, you're going to be pushing the limits of your tire's load limits.
I respectfully disagree. People in europe drive small cars, they tow trailers and such just fine.
You can buy hitches for vauxhall/opel corsa's (chevy, chevy here) all day long without issue.
This is not towing, this is sticking 200+ pounds of motorcycle 24" behind the car. This is all tongue weight and is going to bend or break fasteners or welds and dump a nice bike on a freeway somewhere. Think of it as over 400 foot pounds of torque on the hitch mount BEFORE a bump is encountered.
-enganear
I actually had three at one time, a driver (2nd gen), an autocross setup one (1st gen V4), and a parts car, plus a couple of the related sedans as driver & parts backup. You had to be a fanatic to own even one Saab. But that's for another forum.
Installed the Curt 11384 hitch. Was the easiest install of a hitch yet and I've done a half dozen or more. Couple tips I found that will help my fellow Speed 3'ers:
Tools:
18mm Socket
1/2" drill bit
Screwdriver
Ratchet (preferably 1/2 drive so you can pull tight)
Extension
The way to fish with supplied wire is to route the spiral end through the hole then out the end you fish from ,then screw the bolt on and pull it thru. On the horizontal bolts, fish thru end of bumper beam.
On the horizontal bolts, hold it in position with a screwdriver through the existing hole in the frame to keep it from falling thru when screwing the nut on.
I needed no cutting and followed the directions with ease. The hitch is barely visible.
I'm just installing my hitch and this thing gets fastened to the bumper!!!!!(nailbyt)
Is the bumper strong enough to support the weight of the hitch, rack, and 2 bikes? (huh)
The hitch on my Miata was bolted to the frame...thats the way it should be...
Anyone have a long term review they can post and see if there is any long term damage...?
Thanks!!
I'd also like to see some long-term reviews. Hopefully someone will respond.
Did you install the Curt hitch? It fastens to the bumper?
Look back at post #33, that was my original install with pictures. Used it a bunch of times over the past few months and still love it. The Thule T2 is also great. My Turner weighs around 33 lbs and my specialized weighs about 28 lbs. No problems.
Cheers
Peter.
Cheers
Peter.
