Im guessing 320whp!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lies 321! lol
uego is proven to be the most accurate.there was a wideband shootout not to long ago and the uego was the best
do you have a link of where you saw this?
I'm trying to pick the wideband I want.
i went in at 3169 with me in it and im 6'5 210. So it should be right around hwere yours is. I dont know how accurate the the scale is because the other time it was 3360 with me in lol, weird
i don't think 1 psi - especially if it is untuned/zeroed out as it says - is going to do much, especially not shave a half second off your time in the 13s. it takes an exponential increase to do that once you are in that bracket.
i don't want people to think this is the magic key to reach 400whp either. i'm not a fan of pushing 350+ on stock internals regardless of how well tuned the car is. i do think its going to make a big difference for a lot of people.
uhh i have it done in my speed.. why dont u give this guy a chance.atleast hes putting an effort in like i did.. and ull never see 400hp without breaking ur motor with these cars internals suck. and a walbro plus the PG pump should mean results should be 50% better then stock. personally id listen to ken i dont trust my motor at all with everyone blowing them up on the 6 side.. now with the right modifications and a good tune i think we'll see some good numbers and a less of a risk of blowing s*** up.
I beg to differ Ken.. They said this on Ford, especially with lightnings that only had these sorry ass coated semi forged pistons with non forged rods.. i ran over 540HP to the rear wheels on that motor for 4 years with no issues.
350 on these engines is nothing when tuned correctly. These Rods are so tiny, they arent going to go exit left. If you keep it at below 11.3, your pistons arent going to give you to much trouble. Im willing to test this shortblock soon![]()
Wasted your money and your time with an intank pump and that is NOT going to solve the high pressure fuel starvation on these cars. Wont work, dont bother.
Ge the HP pump from PG, get your car on the dyno and with that GTR- turbo of yours, you should see damn near 400 hp if not more if properly tuned...
Learn how to tune your car and you wont see it destroyed. Common Sense my friend, it goes along way. That intank pump supplies the fuel to the high pressure pump.. Thats all its going to do. Waste of time and money tp upgrade that pump anytime soon. As for these people are blowing their motors up in the 6 side for what reason? Yea. look at their mods and the safety behind them. I dont want to act like an ass, but any moron can put parts on their car and go beat on it. I cant believe the countless post i run across on here where people are tuning via piggy back with no wideband meter installed and playing " guess the calibrations ". Or the classic, bolt the big turbo on with no tuning, fuel or monitoring.. smart decision, lemme tell ya.
CP-e tells me that this is not the case.And now that you're holding boost longer, is the throttle plate staying open longer as well? I believe the throttle plate closing in the upper rpms was the major cause of the boost dropping off. Maybe now that you have more fuel available, the ECU no longer closes the throttle plate. Can you log throttle position with the standback?
Also, because there is more fuel available, the throttle plate stays open longer, with less of a dance for more power to redline. This is because the throttle plate doesn’t need to limit air intake because of the fuel pressure drop from the pump. The pressure drop is no more.
