Stuttering G O N E.
btw i do not understand this car. it does the opposite of logic.
When its cold, cars run leaner.
When you modify the intake/exhaust, cars run leaner.
So ok its 26 degrees outside, my car only stutters when its cold. i went to datalog some runs. Sure enough 4k rpm begins to stutter and doesnt slow down till 6k. ok i got that on file. next i go to the extreme and add 8 percent of fuel after 3k rpm till redline. i get on it, 4k rpm BOOOOOM it felt like some1 slammed the brakes hard. my friend was following me and called me instantly saying that i might have lost my bumper in the fireball i shot out. So i try it again, same exact result. VIOLENT boost/fuel cut. So im like ok this makes ZERO sense, so i lean the car out -2 after 4k rpm. i have NEVER felt this car pull harder in my life. now im going to list all the things that make ZERO SENSE.
1. only happens in cold weather. Cold weather equals leaner conditions
2. only happens witht he forge bpv. Stock one leaks and doesnt hold boost.
a leaking bpv richens the car, not leans it out. wtf
3. how is my car running richer then stock after i/tbe?
4. this car is gay....but quick as hell now
5. i have a headace and can't believe leaning it out solved all my problems.
6. i feel stupid for spending money ona fuel pump(rockon)
