wow has this happen to anyone
LostSoulx316
Contributor
2003 Protege5
well i did my mounts today and the front mount was doing nothing cause it broke. heres a pic that would explane my headers braking in half
( thank ken for fixing them)
got a ? does the driverside mount suppose to be easy to put back after you put the pushing on or is it a tight fit?
It's a little tighter going in with inserts if that's what you were asking. Nothing crazy tho.
ok well i got to put most of my wieght on it to get it in
and do i need to put them back
Oh, s*** you said driver's side. Probably should hold motor up with jack on that one or passenger side. Thought you said front at first. That one doesn't need jack if others are OK.
Has this NOT happened to anyone?
Have you installed the AWR inserts? If so, you don't need those rubber thingys in the second pic. Mine were tight, but went in ok with some WD40.
I had to literally beat my driver's side mount with a rubber hammer to get it back in place with the AWR inserts. That thing is going nowhere...
it happens quite often. The OEM motor mounts are garbage...replace them lol
