This is for the driver's side and does not hold for the passenger side, because on the pass side, the colors of the wires are different. Maybe it was supposed to be that way? Weird.Dim said:Figured it out by throwing a multimeter on it.
SOLID: HOT
STRIPED: GROUND
The ground is within the connector. One wire is ground and the other is hot.can you take a pic cuz on mine, i have to have it touch the ballast for some reason. does it just have to touch metal to ground? i dunno, thats what happens when a noob tries to do something they dont know how to do. also, my high beam on the driver side isnt working.
What if the hot and ground touch while the lights are on? I now have a dim light because I think those two came together by accident, am I now in for a new wiring harness all together?
I think you would blow a fuse if they touched.
OK...It's kinda hard to treat my $99 HID kit as the $6 LED bulb.
