Hood Struts Instead Of The Prop
haven't seen any, but there was a vendor here making them for the Protege...
Not sure if he ever got access to a 3 to prototype on.
Do they carry ones that are MS3 specific?
Does anyone even know if the strut kit for a Reg. 3 would fit a MS3?
I know the MS3 hood is probably heavier. Not sure if that has any effect or not.
If you notice in my siggy, plus that I said "LOVE em", I have them on my car.
How hard was the install, i looked online and it didn't seem to bad if i had a rivet gun. Also, did u protect the holes you drilled in the car, i could see those becthought id post this to help people out as recently wev had quite a few people having problems with bios
all the beep codes are different depending of who makes the bios , but here are some of the more common ones
What is a BIOS Beep Code?
When you power on a computer the BIOS immediately takes control of the computer and performs the P.O.S.T (Power On Self Test). At the end of the POST the computer will play an audible 'BEEP' through either the PC's internal speaker of through speakers attached to the sound card (if you have a built-in sound chip). If the POST completed successfully without detecting any problems with then system will play a single short beep to let you know the test is complete and the computer will continue to startup and load the operating system.
If during the POST the BIOS detects a problem it will normally display a visual error message on the monitor explaining what the problem is. However, if a problem is detected before the BIOS initializes the video card, or a video card is not present or not detected then the BIOS will play several 'BEEPS' through the speaker to let you know there is a problem. Depending on the type of the BIOS you have the BIOS may play beeps in a specific pattern to indicate what the problem is, or play the same beep a number of times indicating the problem. It is very important that you pay close attention to the number and/or pattern of the beeps your computer plays on startup.
Below is a table of the most common AMI, Phoenix and Award BIOS beep codes.
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video cardthought id post this to help people out as recently wev had quite a few people having problems with bios
9 - 2 - 1 Video adapter incompatibility Use a different brand of video cardoming potential rust spots down the road?
How hard was the install, i looked online and it didn't seem to bad if i had a rivet gun. Also, did u protect the holes you drilled in the car, i could see those becoming potential rust spots down the road?
Install is pretty easy. You will need a short drill motor as the holes in the fender are quite close to the hood. It helps to have a second person holding the hood up as high as it goes while drilling. Be careful drilling the hood; the drill goes though really quick and if you aren't careful you can put a ding in the hood from the underneath. I used some anti-rust primer from a can, applied to the holes with a Q-tip. Watch out that you get the correct brackets for each position, they are slightly different; pay attention to the description.
I did this mod the afternoon of the day I took delivery of the car. I hate the stick!
Looks nice when it's up but it doesn't raise it much over stock. It took an hour with a friend helping. I was in a neck brace and he didn't know how a rivet worked.
Here are my Hood Struts.....
Very nice!! I'm going to have to get me some of those. My old Pontiac GTP had struts on it and I miss them :(
I have these too. They are great, buy them.
Install is not hard at all, and the only tricky part is the drilling.
A couple of tricks for not running the drill through to your hood:
1) USE A PUNCH FIRST to make a starter indent. This will keep the drill straight. It's included on the instructions, but I wanted to mention it again here.
2) When you drill through, run the drill forwards until just before you are all the way through. Then reverse the drill and press a little harder. You will make progress slowly and when the bit does go through it will not catch and jerk towards the hood. If you are running the drill forwards this will happen very suddenly and you risk damaging the hood.
BTW you can borrow a pop rivet gun from most auto parts stores. They will charge the price to your credit card and refund it if you return the tool. Call ahead to see if they have one. Or just buy one like I did.
