new Mazda3 rear diffuser
major error
07 Mazda 3 GTS HB
So I've finally gotten around to installing the new rear diffuser on my 3...
Here's a quick pictorial:
BEFORE:
Tools required:
Flathead screwdriver
Phillips-head screwdriver
panel removal tool
eye protection
Patience
The undercarriage....you can easily see the 6 plastic phillips-head "pop-screws" and the 2 plastic "pop anchors". Removal of the screw-in type is pretty straightforward, but use care in the other 2--the plastic is not exactly flexible, and is easily broken...
Also note that there's a very good chance that there's a good quantity of small bits of tar and gravel caught up in there!
Aside from the fasteners just removed, there are 4 slide-in clips:
One on the passenger end of the foam...
One between the centerline and passenger end...
...and mirrored on the driver's side...
Removal is straightforward--use the flathead to press in the catch, then push the clip up & out of the tab. Since the 2 large straps are disconnected, you can flex the bumper to let them fall out.
There are also a number of tabs on the trim itself that need to be disengaged from the bumper before it is completely released.
It's off...
Part# for reference.
Installation of the new part is the exact reverse, but the bumper foam makes it a challenge to get the center 2 slide clips back in. For one, I had to wedge the clip between the foam and the tab that was just barely pushed through the bumper. Much patience and finagling was required in this step...
At long last, it's on! (dance)
Part# for reference:
Yeah, my car is dirty as sin, but that's what happens when you park near a construction site!
Interesting swap. Looks good with either diffuser no doubt! Wish the mazdaspeed came in that color blue I would have been all over it!
Do You Have The Actual Mazda Part Number On The Box/bag That It Came On Because That Number You Posted A Pic Of Is No Good And Is Prolly The Engeneering Number
sorry, i didnt follow up, but that is the correct part number but you have to add a c to the end
(iagree) whats with the two exhaust ports for the one exhaust too? i understand the function of it but man....
There is a rice neon at the train station I park at that has an aftermarket rear bumper with 2 exhaust holes in the center and nothing coming out. (nailbyt)
i would be scared too. (btw, the new rear bumper piece looks a hell of a lot better)
