Pistons should go one way only...youe may notice it by the size of the valve relief and in the piston skirt, the clearance for the squirters
Ah...one more thing. ''
With the Pauter rods...you WILL NEED to shave a bit off the cylinder skirt...or the rods will hit the bottom of them
Sorry I Dont have a pic of whats needed to be done.
Loading up pics right now!pics pics pics pics!!!!!
And the last pic is of the cam gears, I'm sure i'm right on this just want to double check that these are the marks that are supposed to be pointed at each other. I'm not taking any chances this time.
Igdrasil has been pretty knowledgable, so i'm hoping he'll chime in again. Kooldino have any opinions? And I agree about breaking down the block. Thats why i want to be sure that it has to be done before i do it. And hell no, I dont want to do this a third time!well if that was me I would try and contact someone about shaving the bottom of the cylinder before going balls out. if you had to I would personally break the block down to nothing, then shave it and then go get the block hot washed (dipped) to get any and I mean ANY shavings the **** out of there. now ( I know I know) is not the time to cut corners. do you really want to do this a third time???
It was for sure not just the battery. The motor was locked. It would not turn over till we got it out and on the stand. Then i had to smack a socket wrench pretty good to get it free.if you ask me ( ive only rebuilt these motors a couple of times) it seems that you jumped the gun on this one and all you should have done is go and get another battery first before going this far..... sorry but it looks fine to me, gots clearance fer the sqirters, rods, pistion skirts, "cylinder skirts". cant amagin that forged goodies flex that much at 7.5K and under.
the rod caps were all on backwards. and no scoring. was only turned over by hand like 2-3x.What caps were backwards? It didn't score the crank did it?
its dead on the mark.dead on up top. how about below?
I couldnt get any answers wether to grind the block or not, so i just did it anyways. Not doing this all again.so no milling??
