Canadianzoom
- Silver P5
Nope, Crazy tape work!
fishman138 said:Great write up!
My personal favorite was STEP 9.
habeansha said:How bad would it be if i used that cheapo walmart spray paint and then use the wheel paint clear coat?
wouldnt that protect it from the heat and stuff? Im only using the walmart stuff because i am cheap and they had the colors i wanted (flat black and dark blue)
Yah its better to use wheel paint. It is resistant to chemicals and lots of other things that regular spray paint isn't. But you can try it, you can always repaint them if they start chipping to much. Just make sure to do about 3-4 primer coats, and since your using regulart paint I would do about 5 clear coats. So are you going with the blue or the flat black?
i want both colors so i am thinking of either just painting at all black with a blue lip thingy or maybe just the outer parts black and the middle part that is the spokes and centercap blue
any thoughts
would using bbq paint help any?
should 2 cans of clear be enough?
Does anyone have suggestions on the brands to look for...I hear people using VHT and Duplicolor, but I was curious if anyone knew of any other brands of wheel paint...I'm looking for a different gunmetal/graphite color. Also, it seems like some people are painting the entire rim while others are only painting the face...I am unsure which I should attempt and would like to hear some feedback on that. I might paint the rims fully (with the tires off) if I can find a set of cheap steelies to drive on. I'm not sure if the remounting of the tires (I only have one set) would tear the paint up to the point that this wouldn't be a good idea. Any ideas on where I can get cheap steelies?
(Sorry, that's a lot of questions!)
