P Panayiotis Oct 19, 2020 #1 Hello, CX-3 1.5 diesel wrench light flashing. Any idea what the problem is? Thanks!
rsvinylgraphics 2008.5 MGM MS3 Contributor : 2008.5 MS3 Nov 19, 2020 #2 Did you look in the owner's manual? A flashing wrench light normally means maintenance is required, such as an oil change.
T tonyb760 Aug 5, 2022 #3 When flashing (SKYACTIV-D 1.5, SKYACTIV-D 2.2) The sedimentor separates water from the fuel. If water accumulates in this filter, the warning light will flash. When it does, consult an expert repairer, we recommend an Authorised Mazda Repairer as soon as possible.
